I am using driver 0.961 and totalmixfx 0.915.
My Controller is an ICon (www.icon-global.com) I-Controls V1.01. They have a little Windows tool, called I-Map where you can setup the USB Midi-Device. Also Mackie Control is possible.
So to make the trim-gain issue (if it is one?) more easy to understand. Here are my steps.
1.) Exit TotalMix FX
2.) I reset Total Mix FX to defaults (delete AppData\Local\TotalMixFX\*.xml)
3.) Start TotlaMix FX, Set MIDI-in to ICons Controller, Enable MIDI Control.
4.) I can now control the inputs of the default submix Out AN1/2, e.g. chan 1, 102 = AN1. I can move the fader from 0-100% without any issue.
5.) I set the fader, chan 1, 102 = AN1 to 100%, then I setup a button on the I-Controls to chan 1, 45 for the trim-gain function.
6.) I enable trim gain with that button (even if I can?t see it, it work!)
7.) Now I move the fader from AN1 from 100% to any other value via midi without any problem, except 0%. Whenever I reached 0% the fader stops moving at all --> the current issue!
8.) If I disable trim gain by 45 again, I can move the fader as before. Enable trim gain agin works again until 0% is reached.
I hope my explanation is understandable.
To understand my requirements better and maybe to have another better idea for the setup. Here it is:
I am one of two DJ?s which working always togehter. We are using 2 PC?s. One for DJ, one for VJ. RME Babyface (hope i come next week) will be for the DJ-Set, 3 chan musicsoftware, 1 chan microphone (Echo etc.). The babyface will go via adat to fireface input. fireface drive also max.9 chan musicsoftware. The 3 Stereo outputs of fireface will go to one analog mixer (the mixer is mainly for plan B, and EQ settings, due to RME not support this via MIDI yet.)
Now I need to control via the I-Control MIDI 3 submixes which are the 3 Stereo outputs of fireface. That mean, I need to control the 8 Hardware Inputs (ADAT from DJ-Set) and all Software Inputs of the Fireface UC.
I understand during your support that it is not possible to control the inputs of 3 submixes via MIDI. Now I see light at the end of the tunnel to use Trim gain for it. That is possible for me, because there is only a 1:1 link between input and submix.
I am open to any new idea!
Sascha
