Topic: Fireface800 Software Playback Channels and Adat
I'm using A fireface800 with Cubase 5.5 on an intel macbook. All drivers and firmware up to date. I also have a behringer 8 channel ADAT preamp attached.
I only see 8 playback channels from Cubase in totalmix. Should I be able to see more?
I would like to route a total of 16 channels from cubase via the fireface into a 16 channel analogue mixer using a combination of the analogue outputs and 8 ADAT outputs.
I can route audio from the playback channels to the adat outputs without a problem using the matrix. My main problem is that I only see 8 channels of playback in total mix! Cubase has no problem seeing the ADAT outputs through the (f4) in/out busses control panel and I know how to set up and route to buses. I just need to see at least 16 playback channels in Totalmix!
I've probably missed something veru obvious. Please help.
