Doppler wrote:1- Can i use the balanced line level inputs 1,2,3,4,5,6 (rear panel) with external mic preamps and the mic inputs 7,8,9,10 (front panel) to record ten channels at the same time at 24bits/192Khz?
Yes.
You do need to set the correct inputs re.: "Front" or "Back" for inputs 7 and 8 in the Fireface "Settings", but from what you wrote, you understand this. For that many channels with a 192 kHz. sample rate, you should probably be connecting your Fireface to your computer with a Firewire 800 connection.
Doppler wrote:2- Are all balanced line level inputs converted by the Fireface A/D converters?
Yes.
With the Fireface 800, you have ten channels of Analog to Digital conversion.
Doppler wrote:3- Can i plug an external mic pre with a +28dBu of maximum output level in the balanced line level input 1 (for example) without overload problem?
Yes, however...,
Just because your pre-amp has a rated max. output of +28 dBu, doesn't mean that it will be outputting that level all the time. You have some sort of gain adjustment on the pre-amp - usually some sort of rotary knob - which you will adjust to suit what you are recording, so that an appropriate level is sent to the Fireface. You have a choice of three levels of input sensitivity with the Fireface: Lo Gain, where you will have a maximum input level of +19 dBu before clipping; +4 dBu, where you will have a maximum of +13 dBu, and -10 dBV, where you have a maximum of +2 dBV. For your pre-amp, I'd choose the +4 dBu setting and be done with it.
Then, all you have to do is open up your DAW software, or TotalMix, and watch the level meters for each channel as you adjust the pre-amp gain knobs while your sound sources are performing a soundcheck. I'd recommend that you set things so that most of the time, your levels are hovering around -20 dBFS, so you have lots of headroom for unexpected peaks. If you wish, you can always raise the level later in your DAW or in dedicated mastering software. With 24 bit recording (and 32, or even 64 bit internal DAW processing), you won't encounter any significant sonic compromises from adopting this approach.
Frank Lockwood
https://LockwoodARS.com
Fireface 800, Firmware 2.77
