Topic: HDSP 9652 Win XP post SP3 32bit new driver / firmware wont install
having same issue here with new driver. card previously ran fine, did a fresh install o/s, see new driver and now this.
card works fine with old drivers.
I am running win xp post-sp3 32bit all updates, i tried updating java , flash etc to see if could run.. but the flash update doesnt run.
I'm assuming its the new drivers won't interface with the card properly until firmware is updated.
Same issue I see new mixer icon in system tray but wont open mixer when double click or right click - mixer ...
I first installed the slightly older driver still on the download page, then 'updated driver' to the new one, it installs the same as JeffM with windows warning etc.
Windows after installing says ' must reboot before using' so I did this and it hung for 30 minutes on windows load up!
I force shutdown with power button 5 seconds, restart, 'start windows normally', same thing again!
I shutdown again restart start windows last known good configuration and i'm back. I updated the driver again just now and said 'no' to restart.
I try the firmware update again but still no luck..
I'll restart in a minute and hopefully can get back to windows
I didnt know there was win 7 64 bit driver for 9652, so if this fails I will try putting it into my windows 7 64 bit ultimate machine. But I just did a fresh install my older PC because I thought you didnt have 64bit driver, so I used older machine P4 ht for fresh o/s install and max 3GB ram just for RME usage.
But I would much rather use a better CPU with it.
