Topic: Missing Channels in DigiCheck with UFX
Two small bugs I found in DigiCheck (last version - 5.32) with FF UFX (USB):
1. When "ASIO" is selected, channels ADAT 15-16 are missing in the "Input Device Setup" dialog.
Also, when Totalyser is selected, "Hardware Level" option is disabled - why is that?*)
UPDATE: These channels are missing only when UFX is connected via USB. When connected via FW, they appear.
Workaround:
Switch to "2-Bar Level Meter", select "Hardware Level" and "ADAT 15/16" channels, and then switch back to "Totalyser" - it's working
2. Some windows are not affected by colors settings from the "System Settings" dialog. *)
Thanks.
*) EDIT: According to the manual, that's how the "Hardware" option and colors settings suppose to work.
