Topic: UFX, S/PDIF & Clock
I would like to connect a playback device to the FF UFX.
This device has only S/PDIF output (no input, can't be slave), so I have to set UFX's Clock Source to AES.
My question is: If setting UFX's clock source to a less-accurate clock, does it affect UFX's working clock and audio quality?
Or UFX will keep using its internal clock and not be affected by incoming clock accuracy (is that the SteadyClock feature?).
Thanks for clarification.
