Topic: RayDat to Lynx Aurora 16 with ADAT LT slot interface - Slave problems
Hi Folks,
I've a new setup with Win7 Pro 64bit, (Nuendo 5 and Wavelab 7 etc )
I have a brand new up-to-date RayDat card connected to my Aurora 16 interface via Lynx's ADAT L-slot interface (all latest firmware + drivers)
I have been running the RayDat in SLAVE-Sync mode changing clock frequencies from the Aurora (as Master clock)
The problem being when switching to projects that use 88.2KHz or 96KHz (and above) the RayDat still locks at half the clock frequency. ie 44.1K or 48K (never beyond that).
I have tried everything to make the RayDat see the correct frequency, sometimes when switching to Wavelab 7 using ASIO driver (not Nuendo) and playing back a 88.2 or 96k wav the RayDat might finally switch to show the correct frequency.
Sometimes after switching clock frequencies the RayDat reports the Aurora as clocking at 44.098 or similar 47.98.
Even setting the RayDat to Master and Aurora to slave sync (adat L-slot) the Aurora has a similar problem seeing the correct rate.
All the usual adjustment have been made with Win7 system sounds etc. so it can't be that interferring.
Any ideas?
Cheers,
Adam
