Topic: Digi 96/8 PST No longer working
Greetings,
I have a Digi96/8 PST that worked for years but recently stopped.  I can still see the Digi settings icon in the tool bar but when I click on it the "Settings" dialog box won't open.  Digicheck 4.53 gives me a message: "Device Opening Error:  Invalid device selected or no device available".
I am using the same computer which works otherwise and haven't added any hardware to it.
When I test the output of the Digi using Native Instruments B4 - the sound starts but cuts off shortly after depressing the key.
Anyone have any clues as to what happened and how to fix it.
Your help is appreciated.
Jerry
Re: Digi 96/8 PST No longer working
Remove the card, clean its PCI gold contacts carefully with a rubber pencil, put back - if this doesn't help you can send the card in for repair. The costs will be announced to you before performing any repair.
Matthias,
Thank you for your response.  I tried the solution that you suggested - but no luck.
I would be interested in getting the card repaired.  How would this be handled?
Jerry
You have to contact your local distributor.
