Topic: Need Help with FireFace UC (windows xp)
Hello, I am looking for help with the FFUC, please.
My target OS of installation is Windows XP, when the
unit is first plugged into the port, it shows up as
5 different instances "Fireface UC MAC (xxxxxxxx)"
I went to the site and read how to install the xp driver...
I cancel the wizard and go to dev manager, then update driver, then no, then instal a sound device, then
Ill select location, then browse then go to the latest driver I downloaded from RME.
* the system error says " no specified driver found for your device "
I did this several time to ensure everything lined up.
I then took the driver files and inf and put them manually in the /system32 and /system32/drivers folders
and restarted the driver update. and it at least found the FFUC this time I attempted to install the driver and reboot and
not working on the return and there were still three other instances of the device in the manager. I installed the driver to each of them as well.
Still not working.... however they do move down to the sound section from the others in the dev manager..
I am suspecting that if a FFUC is flashed on a MAC it is for some reason stuck there.. because Ive tried this same device on a windows 7 machine
and same thing, except windows 7 see's the driver the first time with out me manually having to move drivers.
Im getting a MAC today and trying it out.
If you can help, I'd be grateful.
