Topic: Anyway to download an older driver?
I am trying to find 2.88 for the Mac / FF800, as I have potential clash with the AVID CoreAudio driver under the FF800 2.89 driver and would like to check this out.
Info: If I attempt to boot ProTools 9 with the Digi 003R and the FF800 is on, it will not allow the use of the 003R (which I would like to use because of the Low Latency Option). However, if I boot ProTools without the Fireface turned on, it works fine. This is different to when I had the 2.88 drivers installed.
Ultimately, I am hoping that AVID will eventually have an option for 'no software monitoring', which allow the exclusive use of the FF800 and Totalmix.
Do you have a download area for previous drivers.
Matt
