Topic: Removing FireFaceUC driver from Snow Leopard OS X
I have looked at the list at this topic under tips and tricks
and... the list was;
/Applications/Fireface Mixer
/Applications/Fireface Settings
/Library/Audio/MIDI Drivers/Fireface MIDI.plugin
/System/Library/Extensions/FirefaceAudioDriver.kext
/Users/username/Library/Preferences/Fireface folder
/Users/username/Library/Preferences/com.rme.FirefaceMixer.plist
/Users/username/Library/Preferences/com.rme.FirefaceSettings.plist
When using the new Snow Leopard driver also delete:
/Library/LaunchAgents/de.rme-audio.firefaceAgent.plist
Some of the files did not exist in my system is that OK?
Non-existing file list is as follows:
Re: Removing FireFaceUC driver from Snow Leopard OS X
Everything ok.
Thanks Mathias.
4 (edited by oblique strategies 2011-01-06 08:04:55)
The MIDI In Port A on my Fireface UC does not work. I've tried it with a new MIDI breakout cable & had the same problem.
I just uninstalled the old drivers as per the instructions on the website:
http://www.rme-audio.de/forum/viewtopic.php?id=9233
And I didn't have this:
Nor did I have it after installing the latest drivers.
Can this be related to the Port A MIDI problems?
5
You dont have a MIDI driver on the UC, it is class compliant. As listed in the manual:
/Applications/Fireface USB Mixer
/Applications/Fireface USB Settings
/System/Library/Extensions/FirefaceUSB.kext
/Users/username/Library/Preferences/Fireface USB folder
/Users/username/Library/Preferences/de.rme-audio.FirefaceUSBMixer.plist
/Users/username/Library/Preferences/de.rme-audio.Fireface_USB_Settings.plist
I also updated the above link for newer driver information.
6 (edited by oblique strategies 2011-01-06 09:49:57)
Thank you for your quick reply & for the updated info on the website.
Any suggestions on how I should proceed with troubleshooting the MIDI in Port on my Fireface?
I've done the usual things: new MIDI cable, different MIDI controllers, reinstall/update drivers, etc.
no::roll
7
What about MIDI port 2?
MIDI port 2 in & out work fine.
I removed an M-Audio USB MIDI driver (3.4.0) which my Midisport 4x4 MIDI I/O uses. I am testing the FFUC MIDI port 1 & it is working. :-)
I do require the M-Audio MIDI I/O, so I'll install it later (after testing the FFUC MIDI port 1 for stability) & see if it interferes with the FFUC.
Have you received any reports from FFUC users regarding problems when using the FFUC's MIDI I/O with an M-Audio MIDI I/O?
9
Not yet, but that may well be the case.
Thanks again. I shall continue testing.
