Topic: connection with cubase...
i ve got a problem with getting the signal from my hammerfall II into cubase.
I cant record!!!
In the HDSP mixer are three rows.
In the first i have a signal in channel 8 analog.
In the second i have no signal, because i dont use the outputs.
In the third row i have a output on the phones or on SP.L or SP.R. I can switch there.
What i ve done wrong???
Re: connection with cubase...
You didn't read the Cubase manual. Select the RME ASIO driver and configure the I/Os in Cubase.
Hi MC,
thank you, but id hosted the driver and the Inputs and Outputs in "VST-Geräte/gear".
If there is no Input and i click recording, there is a thin line for the level-meter. If i record with the RME input, there is a thicker line on the level-meter.
I dont know where the mistake is.
so id seen that is not the problem.
I got my Inputs right installed and i had something recorded. But unfortunatly i cant hear anything. I like this signal on my headphones with what im playing, that i have a playback on my phones.
