Topic: Logic + Fireface 800 and Monitoring
Apologies if this seems like a repeat question, but I couldn't find the exact answer I was looking for and therefore felt I should ask the question to confirm...
I am working with a fireface 800 in a live venue where I have the in ear monitors of a singer going through the fireface. The total mix software is great because latency isnt an issue for her because she can hear herself perfectly.
What i want to confirm however, is if I set up a Logic Pro 9 project to record the gig, is it still possible that I can maintain the zero latency for the singer, while recording the rest of the band? Does the total mix routing work as a virtual patchbay without latency?
If I set the buffer size of both logic and the total mix to it's minimal state (I think it's 32), will that still appear to her as no latency? Additionally, I've noticed some users suggesting to turn of the software monitoring in logic - is this a reasonable suggestion?
Apologies if this has already been asked, but I thought as I had not found my answer to check.
Craig
