Topic: Fireface version 3 driver bluescreen issue
I have a problem using the new version 3 drivers for the Fireface 400. My machine is intermittantly crashing to Bluescreen citing fireface_64.sys as the cause. Usually it happens when I move the knob on the front panel no matter how small or large I rotate it. I dont even need to be running any DAW or audio to it and it will still do it.
It was fine on 2.999.2 drivers and as soon as I upgraded to 3.033.0 it started happening. Also happening with 3.034.0 drivers.
I'm running Windows 7 x64 Pro on an Intel DP965LT motherboard with Texas instruments Firewire controller and it has worked perfectly up until the latest drivers. I have rolled back to the 2.999.2 drivers and seems to be working fine again.
Any ideas?
