Topic: Feature request, bus architecture UFX DSP
The UFX lacks a very common feature of a digital mixer as the bus. The price is similar to well known digital mixers like 01v96 so it would be nice to have adequate features.
There are some situations when compression in desired on a group of signals. To do it now you need to make outboard connection - Mix to a output, apply compression, make a cable connection between the output and input, using the I/O capabilities and loosing quality on DA and AD conversion.
I think that adding a "DSP Loopback" button for the outputs could be a solution. When such a button was pressed the signal would be routed to a virtual channel strip in totalmix. Resource wise it would not take much memory of the DSP as it would need to store a single sample for each bus, and make it available as an input (first row of totalmix).
