Topic: SYNC problem with 2 AIO cards -> 2 Apogee Rosetta's -> one has latency
I seem to have a SYNC problem I cannot solve...
My setup = Mac Intel with 2 RME AIO cards, to each one there is an Apogee Rosetta 800 connected via ADAT i/o.
I have one Apogee slaved to the other via the word clock in/out BNC-connector so there's only one wordclock driving both units; I set both RME cards to autosync via ADAT.
When I record, the tracks that were recorded via the second unit (the slaved one for that matter) are 'late' on the grid.
My best guess is, since I cannot use both cards direct monitoring output simultaneously into my headphone monitoring amp, one converter will always suffer from latency and thus the recordings will be 'late'... if this makes sense: is there a solution for this problem?
I currently use the analog outputs of the first card as main outs, these are plugged into the main inputs of the monitor amp, and they're linked through to a little mixer to control my monitor speakers. No problems here.
The only thing is, I can only plug one headphone out plug (the one from the first or either the second RME-unit) into my monitor amp... Is there a possibility to route this internally between the two cards?
Many thanks!
