Topic: Totalmix issue (newby)
Just got my FF400 and love the device. Everything seems to work as expected and i cab record my hardware synths into Ableton and send back and forth to outboard fx gear as well.
Now the funny thing is that totalmix, does not do what it should do. (ableton not running)
Meaning I can only route one input channel directly to the headphone or any other output channel. All the other input channels show live input (on the input meters) but no output appears on any of the outputs whatever i do.
The default preset 2 (first thing i tried ) same problem. Only from input 5 i get stuff on my output channels .
All looks good, matrix confirms in to out asssignement including levels.
Can't be a hardware thing otherwise Ableton would have the same problem i would suppose, but can route all to all in ableton.
Running the 1.7 firmware (uopdated from 1,69 which was loaded originaly in the device) and 2.90 driver (instaklled from scratch, so no old drivers updated) on snow leopard 10.6.6
Any ideas what might be wrong ?
Glenn
p.s. I also can route all playback channels (like itunes output etc) fine to any output. Just affects the analog inputs (have no digital stuff)
