Topic: FF800 - Driver issue - Have to reinstall it on each use
Hi
First post in this forum… excuse my french english (at least better than my french president…).
I use FF800 on a MacBook Pro (10.6.4) with firewire 800.
Everything works fine except that when shut down my computer and reopen it the day after, the FF800 didn't see the host (the little red LED is lighted), Fireface Settings and Mixer opened (as expected) but the sample rate in the Fireface Settings is wrong.
Each time, I had to reinstall the driver. This solution fix the problem but it would be great to use the FF800 without reinstalling again and again the driver.
Thanks by advance for all your support.
Vadim
Re: FF800 - Driver issue - Have to reinstall it on each use
Pas mal du tout...
Eh bien....
Have you tried updating to 10.6.6 or whatever is the latest? And is the driver up to date?
Hi Daniel
Thanks for your answer.
The driver and the flash of the FF800 are up to date.
I'm actually updating Mac OS to 10.6.6. I'll tell you if it change something.
Vadim
Hi Daniel
Sorry, but I have still the same problem.
I update Mac OS and the FF800 is up to date.
This week-end I'd used the laptop without the FF800 and today, when I turn on the ff800 and the computer, the FF800 still have the red host led light on, Fireface Mixer and Fireface Settings popup normally, except that the system clock shows a Freq. at -1851512 !
Again, I have to reinstall the drivers to fix the problem.
It looks like the laptop lose a "piece" of the driver when I use the laptop without the FF800 ???
Thanks by advance for all your help.
Vadim
I´m no mac expert, but on a friends mac, repairing permissions of the system disc fixed issues like this.
Hi Vincent
Thanks for your advice. I've run Onyx this night to repair all the mac permissions. But this morning, the problem still here : the FF800 doesn't found the host and I have to reinstall the drivers to fix this...
Just to be sure, here is how I turn on / off my installation, is this correct ?
1. Connect Fireface & Computer (I use firewire 800 on the direct port on the MacBook Pro)
2. Turn on the Fireface
3. Turn on the computer
For turning off, I do the inverse :
1. Turn off the computer
2. Turn off the fireface
Vadim
7
You might overlook the obvious. Does the serial number stay the same?
8 (edited by VadimV 2011-03-24 14:03:11)
Hi
Thanks to all for your help.
I check the serial number shows on the Fireface Settings and here's the result :
1st session - FF800 is working : Unit #66597513 v2,77
2nd session : I use the computer without the FF800 (I use the built-in one)
3nd session - FF800 Not Working : Unit #66597513 v0,0
4rd session - After reinstalling - FF800 is working : Unit #66597513 v2,77
So, the serial number stay the same but not the flash version (v2,77 becoming v0,0)...
Maybe a clue. Should I update again the flash of the FF800 ?
But the problem was yet here before I update the flash version to 2,77.
Vadim
Have you tried another FW cable?
Hi
After 3 days without using the fireface (i work at home with the built-in), I changed the firewire 800 cable... I cross the fingers... but nothing. Same problem (no host led and wrong freq in the FF800 settings). Again, I had to reinstall the driver, shut down and restart the computer and everything work well...
Help !!!!!!! this "one shot driver" is becoming quite annoying for this professionnel hardware...
Vadim
11
The firmware version not read correctly shows that the FireWire communication is broken. You should have the unit serviced.
Hi MC
Do you mean that I should send back the FF800 unit to RME for they repair the Firewire chipset ?
Vadim
That's what he meant. Before you do, can you test the FF with another computer?
Can I test it on Power Pc Powerbook ?
Yup, driver is here: https://archiv.rme-audio.de/download/macfire_262.gz
Hi
I'hadn't the time to test on my PPC but it seems that the new driver (2,91) solved the problem.
Since I've updated the driver from 2,9 to 2,91 I've made several switch between use the MacBook with or without the FF800 and Laptop & FF800 recognize each others. The host led turn off, the frequency is stable, the device version too.
I don't know what you've done in this update but it seems to work !
I don't know for what, but many thanks...
Vadim
Hi
I've speak too fast... Same issue this morning : the host led is light on, the driver version not recognize in FF800 settings (v0.0) and I have to reinstall the driver and reboot the computer... I'm going to try your last solution : test the FF800 on an another laptop. It was too beautiful...
