Topic: Fireface 800-Windows 7 x64-Sonar 8.5.3 x64 Arming Delay/no sound issu
So I just had pretty much the most embarassing session I've had in my life. I rently got a Fireface 800 but today was the first day I tried tracking a full scale project with it in Sonar. By the end of it I pretty much wanted to smash this thing. So here goes with the issues.
When I go to arm a track for recording there is a delay. Sometimes half a second, sometimes a good 10 seconds. Ok that's annoying but whatever.
Sometimes when monitoring an input I can see the signal coming in via totalmix but the armed track would show nothing in sonar. At this point trying to save or close Sonar causes a crash. On top of this nothing else is able to utilize my Fireface to play audio either. (I wanted to see if it was a sonar thing or a device thing and since after this happens no windows application can access it I'm going with the device driver here.) However if I power cycle the FF800 and load the session again it works again.
Sometimes it will allow me to record a few tracks but then I stop and go to playback or record again and again Sonar seems to not be able to communicate with the FF800 again. This just appears to happen randomly as I can do the same thing 5 times in a row and on the 6th it will do this... or the 3rd or the...
Other times I can see meters jumping in Sonar but no sound from the Fireface. When I go to record a track or play something it has become a total crapshoot.
I seriously had to restart this damn thing 20 or 30 times during this session with clients watching me. I never had this problem with my Firestudio Project and I don't see why I should have this problem with a device that costs 4 times as much. I have had 0 issues with any other device on my machine so if it is in fact my configuration then I'm going to go ahead and say you need to write a more comprehensive driver. I'm not sure if I actually expect to see any kind of support on here since I've read tons of threads where RME essentially says "it works fine over here so it's your computer." The fact that it stops working intermittently definitely tells me something is up on the driver side because I know my machine is not crapping out intermittently and if it was I'd assume more devices than this one should have issues. If it is an issue within Sonar I would've expected a fix to have been released at this point as it has been out a good amount of time and I haven't seen this issue with other devices. And again whatever happens here causes the fireface to not be able to communicate with any windows software ( mediaplayer, winamp etc) either. I saw someone posting about the delay thing and others about the no sound thing many months ago with RME people saying a fix was coming. If this is the case where is it?
I really need some sort of a solution here. It is just not at all stable enough for any kind of work and I don't have the cash to just go grab some other higher end device.
In any case it is absolutely not possible to work like this.
I have an I7 930
ASUS P6T SE
12 GB CORSAIR XMS3 RAM
NVIDIA Video
Windows 7 x64
Sonar 8.5.3 x64
Latest firmware and driver version 3.0.34.
RME let me know if you know anything about this issue. Anyone else that's having this issue please let me know if you managed to solve it or if I am just screwed. Thanks.
