Topic: fireface 400 sounds distorted suddenly after 7 months use
My fireface 400 sounds distorted suddenly after 7 months use.Windows media player plays a mp3..it sounds distorted and I get errors...
Sonar sound s  distorted...I cannot mix my music..
Please help ..
3.8 Gz intel PC 4 gb ram....pci card installed from the beginning to get a firewire port...sp3 windows XP pro
Re: fireface 400 sounds distorted suddenly after 7 months use
windows xp also starts very slowly.......previously that was not the case...
Your hard drive may have slipped out of DMA mode.  Do what it says here:
http://winhlp.com/node/10
If that doesn't help, you may have caught something.  Restart in Safe Mode With Networking (keep dabbing the F8 key during startup until the menu appears).  Download anr run ESET Online Scanner.
http://www.eset.co.uk/Antivirus-Utiliti … ne-Scanner
(Do this now and again anyway, for any Windows computer that uses the Internet.  A negative result is good!  If there's anything bad, it will cure it)
Thanks Laurence..
It was really helpful
Well, don't leave us in suspense!  Did one of those work?  Which?
there was some problem with the hard drives.I think it slipped out of DMA mode.After trying whats said in your first option,it did not solved the problem..instead windows did not boot.I installed windows xp again and now its working nicely.It was a disc problem which affected my OS I suppose.I am not good at these internal DMA ,s and stuff.
Thanks to you so that I realised at least my RME is safe...
cheers
Regarding ur second option I scanned and nothing affected the computer
It's possible you have a failing hard drive.  One problem - well OK.  If it plays up again, replace it.
