Topic: Multiple FF800's in Parallel or Series?
How do I configure multiple FF800's? I need 24 inputs and 24 outputs simultaneously. I use a Mac Pro with Logic Pro 9...and a bunch of other stuff that is NOT Firewire 800 gear.
Re: Multiple FF800's in Parallel or Series?
The FF 800 has 28 inputs and outputs, so you don't need more than one.
3 (edited by throctal1 2011-05-21 06:58:52)
Yeah, but what kind of changes do I have to go through to get these 28 input and outputs to work concurrently? Do I have to use connectors that require some type of conversion from one type connector to another (such as a 1/4" to RCA as an example, or something to that affect)? Will they all work simultaneously with the same output levels? Can I assign them individually or will some outputs be controlled by others? I'd rather have some continuity in my cabling since I have most of the cable wired up as balanced TRS snakes already.
4 (edited by Laurence Payne 2011-05-21 11:47:28)
If having 24 IDENTICAL inputs is a priority, your neatest way would be to use the 8 Line Inputs on the FF800 plus 16 channels of external A/D connected to its ADAT ports.   Additional FF800 units would be an unnecessarily expensive way of doing this.
Thanks for your help and insight in this matter. I am not trying to spend money I do not absitively, posolutely MUST! :-) I'm new to the rme family so I'm probably going to ask some obvious questions like:
Do I need a physical ADAT to take advantage of the a/d's or can I use some other a/d's in place of them? If so, what unit can I use and how do I hook it up to my system?
Again, thanks for your help.
2x used RME ADI-8 Pro's off eBay for $400-$500/ea.  Those two units along with your FF800 will get you 24 good LINE LEVEL analog ins and outs.  Of course, pretty much any ADAT AD/DA converter from $200-$10,000 will work to utilize the FF's ADAT ports for Analog I/O.  A physical Alesis ADAT machine is not required - or wanted :-P  Just AD/DA converters that use the ADAT Lightpipe protocol are all you should need for I/O expansion - clocked accordingly.
cool
2x SSL Alphalink MADI AX
ADAT machines as such barely exist any more.  But the connection they used has survived.  Just think of an ADAT port as a socket for an 8-track digital multi-core!  There's a wide choice of equipment that uses it, from many manufacturers.
Thank you all for your help! I have now seen the light(pipe)!!:-)
