niceboy wrote:[img align=L]http://www.froozenfish.com/screenshot2.jpg[/url]
1. We need to know now first if the Coaxial MADI is the same quality as Optical MADI
2. Is this set up going to have any problem going from Computer 1 ,
to Front of the House through the MADI-CARD out and signals back to Computer 1,
in order to do mixdown to Stereo , in Computer 1.
3.Most boards seems to have optical MADI, but the Coaxial might be a better way to explaine this for you, because they are totally separated as cabels.
4.We think that in this situation its better to go back to ADI 648 MADI rather than to the HDSPe card.
5.We also want to know if both Coaxial and Optical can be used in the same time goin out FROM HDSPe
to Front of the House , and they other way in and out to the converter ADI 648 using both MADI.
Thats important because we cant test that here and that would be another way of planning this.
That way is not the easiest way in our opinion ,for going back to Computer 1 from Front of the House,
but might be an easier way to mix in both digital and live drums together in our MADI Computer,
before mixing them together with the rest of the Band and the Singing.
6. If we can use them in the same time we also want to know,
if you can help with a solution for the optical Madi-Cabels to make them separated,
or abel to do the same thing. ( going out from the Madi card and back direct into ADI 648 )
Thats a little bit assuming that big boards works better with optical maybe.
7. All this is about finding it wrong to go back to the Madi Computer from Front of the House.
Thats because we intend to do Stereo Mix Down in Sonic Core Computer 1,
and then conversion back to ADAT is sort of a short-cut coming from Front of the House.
8. Before we bought this card we compared it with the more cheap SSL- card ( Extreem Madi ),
with two optical in and out , and we bought HDSPe because we assumed all this was possible to do.
They say its possibel in theire card to go both ways to f.ex . the Venue boards and also the other way,
back to f.ex a converter, but we want to know all possibilities.
9. The converter ADI 648 has to work either Coaxial or Optical, as far as I can understand,
so then the splitted direction of ours ,is maybe a good or a bad solution ???
Its a question
Bear Of Moon
