Topic: Multiface + ADI 8DS, adat latency ?
Hi
I'm using a multiface and a ADI8DS, mixing through a DIY mixer. I have some phase issue between the output of the multiface and the ADI8. For exemple I have a snare on the out 1 / multiface, then the same snare (thru an aux send in cubase) processing a external comp from the out 1 / ADI, this set-up gives me phase issue.
But if I'm only going thru multiface or ADI outs, no problem. (Out 1 no comp and out 2 comp).
So I guess there's some latency in the ADAT processing ?
How can I calculate it ?
