Topic: Babyface: controlling ADAT level by wheel
Using a Babyface with driver 1.59, Totalmix FX 0.942 and firmware 184 on Mac OS X 10.6.7.
I must be doing something dumb but I can't get the wheel on the Babyface to control the level of ADAT output 1-2 which is my main output for monitoring.
If I understand the Help correctly the following should work:
- Go to TotalMix FX
- In the Control Room channel strip Assign (dropdown) the main out to AS 1/2.
- Set the Babyface to 'Out' (LED) using 'Select' (button).
However, whatever I do, the wheel keeps controlling AN 1/2 in this mode or PH 3/4 in Phones mode.
Using AS 1/2 as the phones output also doesn't help.
It must be something silly, but how do I control ADAT 1-2 from the Babyface panel?
Kind regards,
Jorg Schellekens
