Topic: Controlling UFX TM via MIDI commands from a MIDI port on the host
I'm running Mac OS X 10.6.8 and have the latest drivers and firmware for the UFX.
I'm trying to send it the MIDI commands that are documented on page 77 of the manual. I'm sending the commands from a USB MIDI port on the host -- not one of the physical ports on the UFX. I select this port from the drop-down menu in Settings, MIDI Input.
The master volume control works fine (CC7 on Ch 1). The volume goes up and down as expected with my controller.
However, none of the NOTE commands (like snapshot select) work. I can verify by MIDI monitor software running on the host that the commands are being delivered correctly, on the correct channel (1) and with the correct value (NOTE 54, for example, to recall the first snapshot, NOTE 55 to recall the second, etc.)
I just tried this via Ports 1 and 2 on the UFX itself, with the same result: master volume works, but the note-based commands documented on page 77 do not work. I am of course changing the MIDI Input selected under Settings > MIDI Controller each time, and also verifying with software on the host that the MIDI events are arriving on the selected input port.
-Luddy
