Topic: adjusting input trim of Fireface 400 channels 5 & up
In the Win7 fireface 400 driver interface, you can adjust the input levels of channels 1-4 from the 'Analog' tab. However, there's no way to adjust the input levels of the other inputs that I can see there. I figured I would look in Totalmix, however, according to Jeff of Synthax in another thread, "TotalMix actually has nothing to do with the audio for recording (only monitoring)." Strangely, the manual (even the most recent version I just downloaded) says on p.9, section 5.2 of the Quick Start: "After the driver installation connect the TRS jacks or the XLR jacks with the analog signal source. The input sensitivity of the rear inputs can be changed in the Settings dialog (Input Level)" (I suspect that only means the dbU).
As far as I can tell, though, I can only adjust the input levels of channels 5+ from the control knob.
If this is the case - why? Seems like it would not be a big deal to have them all controlled from the driver interface. I wouldn't care except that the FF here is not located very close to my computer.
I apologize if this has been asked previously in another thread, the search engine did not come up with any hits regarding this issue.
e
