Topic: FF800: ADAT sync problem on Mac w/ driver 2.93
Hello folks,
first my specs:
- FF800 with firmware 2.77, serial no. 2259228 (purchased in 2006)
- Driver version 2.93 on Mac (I'm a long term Windows user currently moving to Mac)
The FF800 is connected to a Presonus Digimax FS through both ADAT links. The FF800 is configured as sync master, the Presonus is configured as slave.
In standalone mode (after switching on the FF800 and the Presonus but before connecting the FF800 to the Mac), the FF800 and the Presonus are perfectly synced.
However, when connecting the FF800 to the Mac, as soon as the connection is established and the FF800 control panel has launched itself, the FF800 and the Presonus go out of sync.
In the FF800 control panel, the FF800 is still configured as sync master, but the two ADAT indicators keep changing from "lock" to "no lock" and the two ADAT LEDs on the FF800 keep flashing, while the Presonus audio inputs do not work (as expected).
What I have to do is to click once again on the sync master radio button in the FF800 control panel, although it is already selected. This cures the problem.
Never had this problem on Windows, though. As said, I'm using the FF800 since 2006, so I think I know what I'm doing, especially how to use the FF800 and its control panel and mixer, how to flash the control panel and mixer settings to the device and all this stuff.
If possible, please help. Thank you.
Best regards,
soulianis
