Topic: Fireface 800 Inputs Q.
Hi guys.
Recently I started using Fireface 800 and a Yamaha O1V96 mixer on a mac 10.6 os. I read the manual and I figure it out how to wire but there is one thing I still has to get it right and I thought only you could help me out properly.
I want to figure it out the inputs. I used to have 13/14 channels as inputs now I got 11/12, which means SPDIF. I change SPDIF in to ADAT2, Clock Mode to AutoSync and the 11/12 channels in the total mix are off. How to set up RME properly? it est channels 13/14 as inputs that will be used in ableton, for mic etc.
In ableton I set up A1 5/ A1 6 as outputs, and presumably 13/14 as inputs, is this correct?
Thanks a lot in advance.
Re: Fireface 800 Inputs Q.
Which settings should be set up to get sound from channel 13/14 instead of 11/12 people? I'm a bit out of time until i figure it out myself, is this so hard to answer?
Thanks. Redon
fireface 800
mac os
yamaha o1v96
There is no way to change input channel assignment. If you are using an SPDIF connection, it will be 11/12.
