Hi David!
From my experience, if you want the BCF2000 to work well - with the faders responding to tmfx, - you should try to keep the controller in mackie control emulation mode. (not editable)
If you need to edit the mackie control commands you can do that with LcXmu (LC Xmu costs US $50.00)
It allows you to use multiple controllers (or just one) to emulate a real mackie controller and you can freely assign the buttons and faders.
Of course you're still limited to what the mackie control protocol can do with Total Mix. So no fader skipping(/disabling). At least not until RME comes up with a solution to organize or choose your controlled channels somehow. :-)
But for now.. (only if you want to go this far)
LcXmu also allows you to bypass any midi commands coming from your controller. (The BCF2000 still sends some type of midi commands even when in mackie emulation mode) and if you want, you could use Bome's Midi Translator (59 Euros / approx. US$ 85 + conversion fee) to change the midi commands sent from BCF2000 to ones that control a specific fader or button in TMFX. (Direct output bus selection via midi etc.) Of course this costs a little extra, but for me this has been the only way to achieve my goal. Also it's always nice to support small companies that make good software.
For this to work, you have to make virtual midi ports and route both - midi coming from LcXmu, and midi coming from Bome's MT - to the same virtual midi output (You can do this with Midi Patchbay - This one is free.) and choose it as the controller input in TotalMix preferences. Also you have to do the same to the midi coming out from TMFX to LcXmu, to get the feedback working.
Best possible way is to use two (or more) controllers with LcXmu. I've got the BCF2000 (in mackie mode), and BCR2000 in basic midi mode. LcXmu provides a sysex file for the BCR that works very well. You get the led feedback for mackie controlled parameters. (for standard midi commands - bypassing LcXmu straight to TMFX - the feedback naturally doesn't work.) You can also edit the BCR to send commands understood by TotalMix. Simply bypass them in LcXmu and route to the virtual port needed.
And to ease your work there's of course the MIDI Monitor (free also)
With this you can check what midi commands your controller sends..
Something I've done with this setup:
(My setup only uses 8 stereo input channels (small mixes actually) that I've organized by routing thru adats. So I never have to move the channels left or right or between rows.)
-BCF controls 8 channels in mackie mode. Pans, volume, mute etc.. all feedback also goes to BCR at the same time if something is mapped to both.
-3 buttons in BCF change to submixes with effects. (two with mackie commands and one with basic midi -> changed the command with Bome's)
-one button triggers the trim mode for controlling volumes.
-I also got the "mackie arrow buttons", but I've reorganized them a little differently with LcXmu.
In BCR2000:
-One Row Controls volumes when trim mode on.
-One row controls reverb sends, and when I touch a knob, it simultaneously switches to the submix with reverb send levels. -> This was done with Bome's as well.
-One row controls delay and fx sends levels the same way as with reverb.
-4 buttons select sub mixes and trim mode the same way as with BCF.
-Of course the BCF faders also move when I use the BCR to control levels.
The only bad thing is that I get the same feedback to all - volume, reverb, and effects rows in BCR - This is because they all are controlled with the 8 available mackie channels and only the submix changes. If it would be possible to use midi to control faders in submixes that aren't currently selected, the setup would be a lot better. I wouldn't even need the feedback for effects if they didn't change with submixes.
Everything works very smoothly with my setup. No problems with midi panics or anything. And I've had this setup running for a couple of months now. But if you go for it, do it on your own risk. I just wanted to give some ideas and say what can be done if needed.
Some of the available midi commands of TMFX in a basic format: (To me the hex commands were a little confusing at first.) HeadScratch
Row 1 Faders: (value 0-127)
AN 7-8 = ch1, cc 109
Mic 10 = ch 1 cc 111
Mic 11 = ch 1 cc 112
Mic 12 =ch 1 cc 113
AES EBU = ch1, cc 114 (B0 72 pp)
Row 2 Faders:
ADAT 13/14 = ch 6 cc 112-113
ADAT 15/16 = ch 6 cc 114
Output Bus Faders (0-127)
AN 1-2 = ch 9 cc 103
AN 3-4 = ch 9 cc 105
ADAT 3-4 = ch 10 cc 103
ADAT 5-6 = ch 10 cc 105
ADAT 7-8 = ch 10 cc 107 0-127
Phones 1 = ch 9 cc 110
Phones 2 = ch 9 cc 112
SELECT OUTPUT BUS:
AES = ch13 cc116 val 0-127
ADAT 1-2 = ch14 cc 102 val 0-127
ADAT 3-4 = ch14 cc 104 val 0-127
ADAT 5-6 = ch14 cc 106 val 0-127
ADAT 7-8 = ch14 cc 108 val 0-127
ADAT 9-10 = ch14 cc 110 val 0-127
ADAT11-12 = ch14 cc 112 val 0-127
ADAT 13-14 = ch14 cc 114 val 0-127
ADAT 15-16 = ch14 cc 116 val 0-127
PH9/10 = ch13 cc112 val 0-127
PH11-12 = ch13 cc114 val 0-127
trim gains = ch 13 cc102 (BC 66 00)
