Topic: ff 400 channel 4 and 5 output problem
morning Daniel,
I own a ff 400, and recently have had problems with the outputs jack sockets on channels 4 and 5 on the rear of the unit .all the jack sockets along the back appear to have got a powdery corrosion build up forming around them. I have cleaned them up as best as I can, and still channel 4 output socket not working at all ...nothing from that socket ,,but channel 5 will now only work when the jack plug is slightly pulled out of the unit, if the jack is fully engaged channel 5 is dead.
have you any experience with this problem.......thank you for your help
regrds
