Topic: Midi input not working on ufx! Can anyone help?
have been triggering midi in pro tools 9 on imac through the fireface ufx for some time now. All of a sudden the firreface is not showing ANY midi activity lights when midi keyboard or electroioc drumkit is played?
Just did all updates - nothings changed. Tested midi inputs through midistudio - no activity!
It does not seem to be pro tools problem  - Please can anyone HELP!
Thanks,
Craig
Re: Midi input not working on ufx! Can anyone help?
You tried both inputs of the UFX?
i have a similar problem.
i can't get any midi in to the ufx.
- midi out works great
- i checked both cables
- i tried both midi inputs on ffufx.
- im sending from td-20 (i know it is set correctly and are sending midi to ffufx)
- it has worked before
- the led is on solid yellow,(on the midi in STATE led in front) isn't it supposed to only light/bling upon receiving midi data?
- i have installed lion
(i should also mention that this happened  after my mbp 2009 been in for a logic board replacement)
could it be a lion problem?
i have a novation sl, on usb midi and it is working fine.
i use
os x 10.7.1 - Logic 9.1.5
Morten Venli
The only way to check it is to connect the UFX to a different machine...
Couple more thoughts:
The solid yellow LED sounds like it's receiving a constant stream of Midi clock messages.
   OR
It could be a MIDI feedback loop - if you have MIDI thru set to "on" on the TD-20.
Other thoughts:
Can you try the Novation SL hardware midi output to the back of the FFUFX instead of USB?
Also, try another modi monitor app, such as MIDI Monitor: http://www.snoize.com/MIDIMonitor/
Hope this helps,
Dave
