Topic: W52 Eprom
I have a  Hammerfall (blue PCB - NOT REV 1.5) and also wish to install W52 - provided it's the right EPROM for me to utilize my expansion board for 24-in/24-out - as it stands now it is 16-in/16-out aka. 9632
Re: W52 Eprom
PCI DIGI series of course
3
Re: W52 Eprom
9636? And what is the purpose of your post?
Re: W52 Eprom
as it stands now, I have RME Hammerfall DIGI-9636 with expansion card (8-in/8-out ADAT/TosLink + BNC WordClock) making it a 9652 minus the W52 EPROM - correct me if I'm wrong??
In order for me to make FULL use of ALL 24 physical ins/outs - I would need to swap the W36 EPROM with W52 - correct?
Is there anything else I should be aware of?
5
Re: W52 Eprom
Where did you get the expansion board? There are two, not compatible versions.
Re: W52 Eprom
The expansion board came with the Hammerfall DIGI9636 - purchased second hand.
What makes them not-compatible ??
7
Re: W52 Eprom
The version number.
Re: W52 Eprom
how do I determine that? I do not see any REV numbers on the PCB of the Hammerfall Card.
How do I know what version it is - and how do I know what version the expansion card is and whether it's compatible?
9
Re: W52 Eprom
It is written on the PCBs. The expansion is 1.0 or 1.1.
Re: W52 Eprom
Please mind that the EPROMS are no longer available, to the best of my knowledge. If the two boards are compatible, you should contact the seller of the expansion, to see if he's got the W52 (which he won't need without the expansion).
Re: W52 Eprom
thanks - I know there are some EPROMS floating around the internet.
Re: W52 Eprom
Quite possibly - I was referring to new from the factory.
Re: W52 Eprom
correction ... Both boards - PCI & expansion are labeled REV 1.5
So I guess I'm cool ... correct ?
14
Re: W52 Eprom
Correct.
Re: W52 Eprom
YIPPIIIIIIIIEEEEEEEE !!!! WOOOOOOOOOOOOOWWWWWW!!!
THANKS  guys smile)
