Topic: Firefac UFX redundancy and netbook
1. Can I use the ufx to import files from Fostex D 824 (ADAT out) to PC USB via ADAT as I do it today still with the PCI Card RME Digi 96? so that would be a future option in case of PC upgrade as PCI isn't more on new boards.
2. Is the data transfer from UFX external harddisc to PC via backside USB limited too to 2 GB file size or will that connect the files? How is that situation when using ADAT out to the Digi 96 ADAT in?
3. My goal is more security/redundancy at live recording on may two Fostex D 824 8track recorders (synchronized). There UFX seems to me a good option: splitting the analog outputs of the mixer to Fostex and UFX and save the data on USB drive in standalone mode. For the future there may be the option of using a small laptop connected to backside USB who stores the data too an elimate the "heavy" Fostex recorders. If I use the laptop only for settings, saving the recording files and transfer it via network to the home Audio-PC for mixing, cutting, effects and mastering would do a actual netbook that well? It is often not well seen to run a big laptop display sitting in a church during recording messes or oratoria so shut the desktop down and let ist run looking to the UFX display?
Grosse_j
