Jeff wrote:Optimize Multiclient allows different software apps to use the same playback channels as long as the sample rates are the same.
I hope Jeff will permit me to make a minor correction here... The setting does not "allow" multiclient operation, it optimizes it (as the name suggests... fryingpan
Quoting an earlier explanation from MC:
"It's an erase routine for the buffers, which prevents clicks/noise that occurs on start/stop of a multiclient usage. So if you don't use multiclient you don't need it. If you don't care about an up to 0.5 s noise when starting/stopping in mc mode you don't need it. If you just want the system to work without thinking what to do you will want it."
Sample rates of audio material need to be the same for ASIO applications. WDM will work regardless, with Windows resampling to the sample rate set in the card's settings dialog.
