Topic: Fireface UC setup teething questions
hi folks, just received a UC - very nice so far! latency performance very impressive, and pretty much the same as my previous AIO card. well done rme. couple of things (driver .938 with classic totalmix, win7x64):
- i have the totalmix mixer set to receive midi info. master volume correctly controls main monitor output, but the pitch wheel on my keyboard is controlling the software playback 1&2 channels?!? my previous setup was an AIO card with totalmix, so very familiar with it, and it wasn't doing it with that. have i missed a setting somewhere?
- in playback devices (control panel/sounds) in win7x64, analogue output 1&2 and adat output 1&2 don't appear. all the others are there. there is "Speakers, RME Fireface UC" in the list which i have assumed is outputs 1&2 as when I select this windows audio goes out 1&2. when using the AIO card, all outputs were listed as available in the playback dialogue. which makes me wonder if its related to this next question --->
- am i correct in thinking that wdm and asio should be able to run concurrently and access the same outputs (as they did with my AIO card)? i have windows 7 set up to use analogue 1&2 (which is WDM i assume), and cubase outputting 1&2 asio. when i switch out of cubase to play an mp3 in windows, it won't play. which again is something it did do with the AIO card. i know this is an easy workaround by 'releasing audio driver in background' in cubase, just want to make sure the setup is working correctly, and understand any hardware specific differences between this setup and my last AIO one.
best,
gary.
