RME Support wrote:drainaudio wrote:As per Daniel's post I've installed Lion on both my day-to-day & DAW partitions today ----- onto two healthy partitions I should add, tech tool, disk warrior, all my usual tricks etc etc run before the software install & after (two clones of each partition made for emergency rewind if needed)..
Good - so I don't get sued if something goes wrong...
I must admit I was impressed by the migration assistant that just cpopied programs and drivers from 10.6 to the new 10.7 partition, nothing had to be reinstalled, except for an updat for PT9.
Lol - of course if I'd hosed my system it would have been your fault....I've been making my living in this industry for 60 years & never before had to make a backup of anything..............................ever
It's still working well here after a few days, I also had to install the PT9 update but that was it & that was after upgrading Snow Leopard (not a fresh install) which is fine in my experience as long as you are doing it to a completely healthy existing OS install. Disk Warrior post-upgrade didn't report the need to repair many items, showing that the update/upgrade process is pretty efficient these days.
Haven't tried USB & may not as I prefer to use the FW bus solely for audio, however its handling the largest Logic projects I have (60 odd tracks & lots of 3rd party plug-ins NI, Sound Toys, Slate Digital) better than Snow Leopard - the distribution between the processor cores appears to be not yet all the way there but certainly more integrated, something that a further update to Lion & Logic should continue to refine. Just holding out for 64-bit support now....which Sound Toys are dragging their feet a little on..
I'm also pleased that my proposed new live rig appears to be working very well (Lion) under testing both on this MBP i7 & SSD & MB Black SSD (of which I have several for use solely as live machines) - this consists of Logic running aprox 6-10 mix stems to 6 outputs (at 1024 samples) with a virtual MIDI link (patch changes) to Guitar Rig 5 running in standalone to 2 outputs (at 32 samples) & a MIDI link (patch changes) being sent out to another MB Black SSD running Guitar Rig 5 standalone (both using UFX's with UA Solo/610's as the DI for either guitar or bass)......that's been sat in a corner running on loop since Friday evening without any issues although it's all utterly bored having played the same track 482 times..
I'll certainly look forward to a dedicated Lion FW driver, but in the meantime I is a happy camper.
Cheers..
