Topic: Babyface hates my AKG K702 headphones!?..
Hello!
I am experiencing a problem when using my AKG K702 headphones with the headphone output on the Babyface itself (not the one on the breakout cable). It seems like it doesn't connectgood. The sound sometimes stops, or plays at a lower volume, or only one of the two channels play. If I move a bit the connector, sometimes I find a spot that makes it work again good. And sometimes, when working good, if the audio contains a high volume bass frequency, the same problems start again. The headphone output on the breakout cable has none of these problems!
And the most confusing part is that:
- I have tried the same headphones with a different adaptor and still the same problem
- I have tried the same headphones connected to other inputs (other audio card, hifi, etc) and there is no problem at all
- I have tried the babyface headphone output on the unit with other headphones (like AKG K270*) and there is no problem at all
So.. what is the problem? Why Babyface doesn't like my K702?
* AKG K270: impedance 75 Ohm, sensivity 92 dB/mW
AKG K702: impedance 62 Ohm, sensivity 105 dB/V
