Topic: Babyface - latency issue when recording hardware synth (windows 7)
I'm so glad to finally have this RME Babyface close to me that i'm very upset with this little issue :
I'm trying to record my old Yamaha AN1X into my Ableton Live for the first time.
So i set up the whole system this way (which looks like the regular process to me) :
AN1X sends its sound to the Babyface thru the line inputs.
AN1X sends and receives midi CC to/from the Babyface.
In Ableton Live i've got 1 audio channel receiving the audio signal from Totalmix via AN 1+2, and another midi channel receiving data from Babyface midi port 1 and sending data to the same port.
In Totalmix i have to mute the AN1 and AN2 inputs if i want to listen to the software playback only.
Ok, when i start to play the synth with this setup i have nearly no latency because actually there is no midi conversation in the loop.
But i'm aiming at using Live as a midi sequencer to record the synth, of course.
Here's my problem : when i make a midi clip in the midi channel i was talking about and launch the clip, i've got some latency in the audio playback.
It is something long enough to prevent me from using Live as a real midi sequencer to play the AN1X.
Of course i understand that there must be some latency in this setup because this is where latency issues normally resisde...
I've checked my buffer in the Babyface driver and currently it's 1024 samples.
I tried to go down to 512 samples and i got some audio cuts when playing the sequence.
I'm using a PC with windows 7.
Currently, it looks like i can't use my ableton live as a simple midi sequencer to play or record hardware synth without taking time to fix audio delays issues.
Can someone tell me if i'm wrong somwhere in my setup or did anyone experience this kind of trouble ?
(Sorry for my english, i'm french, and sorry if my explanations are not so clear, i can provide some screenshots if you want)
Thanx in advance.
