Topic: FF400 Clicks and Other Strange Things
Hi
I have a problem with my FF400 and after search a lot into foruns, etc for a possible solution without luck, decided to post here...
So basically i have clicks on sound. Sometimes feels like the unit is "crashing".. This happens for example, with my Prophet 08 with high resonance, even with the volume set to almost the minimum on the synth.
Here's what i detected when those clips occur:
- Green leds Signal on channels 1 and 2 of the hardware light up
- In the Fireface Settings, the clock dialog changes automaticly and back right after for the pre-selected preference. Let's say, the clock changes from Master to Slave, and back again to Master.
- If i record something from a turntable, and one of those occurs, the recorded track sounds slowed down at that part.
This also happens in standalone mode and I have to keep all the volumes on my hardware next to 0 to avoid this kind of clicks
I'm on a mac 10.6.8
Any help will be really appreciated
