Topic: HDSP 9652 and ADAT sync
Hi
Im running W7/64 with Cubase 6.02/64 on ASUS P8P67Pro motherboard with an Intel i5 3,3 Ghz processor.
I have a Hammerfall HDSP 9652 connected to an Alesis AI3 ADAT.
RME driver version 3.27, firmware 108
I have the following settings for the card:
Buffer size: 256
Sample rate: 48.000 Hz (greyed out)
Clock source. Internal (the only one that works OK, all other produces loud noise)
SPDIF in: Coaxial
SPDIF Out: none
AEB and Wordclock not ticked.
Now to my question.
When I set Clock source to ADAT1 or ADATSync I get a really disturbing noise over all 8 channels and SyncCheck flashes on and off.
And when I use internal its OK but then I guess the sync with the ADAT is not properly working.
My other system (with WinXP SP3 and Cubase5) have the some HDSP card and also an Alesis AI3 ADAT connected and there I have no problem syncing to ADAT. I prefer having my recordings done at 44.100, 32 bit float but now I am forced to accept 48.000 with no sync to ADAT.
Is it possible to solve this problem. I have searched the forum but found no answer to my question.
Greatful for an answer.
/Clay Agemyr
