Topic: FireFace UCX ......... a quick question please ?
Hi RME
Regarding the  FF UCX - in USB mode in Windows, is the lowest buffer setting  48 Samples  or  does it go down to  32 Samples or lower  ?
Thanks,
Ben
Re: FireFace UCX ......... a quick question please ?
48.
The UCX can not break the Windows system limitation, but the new low latency converters reduce the overall latency: UC 43/28 to UCX 14/7 samples. Everytime, independent from any buffer settings.
best regards
Knut
Whoa - How did I miss this :-)
2x SSL Alphalink MADI AX
best regards
Knut
Hi Knut !
Thats AWESOME - that means if I am right that overall - input and output - the overall AD/DA Latency is  ~50 Samples  less  than my UC ...... and  ~50 Samples is approx. just on  1.0ms ........ so, whereas my UC gives me a real-world  [ CEntrance measured ]  RTL  of  3.95ms  @  88.2k / 24 Bit ........ the UCX  at  88.2k / 24 Bit will deliver a real-world  RTL of  ~2.95ms ......... please tell me my maths and latency analysis is correct ?
If so, that is simply ASTOUNDING !!!!!!!
Ben
I think the advantage of 50 samples less is not a full ms at 88.2, but around a half and 1.1 ms at 44.1 kHz.
best regards
Knut
HEHE...no wonder.
Nowhere written AFAIK....
Zapp
Zapp
It's written in the product text, in the converter section.
best regards
Knut
Are the converters the same as the ones used in the UFX?  I don't need  a name just wondering if they are different in any way.
You will be able to answer that question with a look at the tech specs.
