Topic: FireFace UCX ......... a quick question please ?
Hi RME
Regarding the FF UCX - in USB mode in Windows, is the lowest buffer setting 48 Samples or does it go down to 32 Samples or lower ?
Thanks,
Ben
RME User Forum → FireWire & USB series → FireFace UCX ......... a quick question please ?
Hi RME
Thanks,
Ben
48.
The UCX can not break the Windows system limitation, but the new low latency converters reduce the overall latency: UC 43/28 to UCX 14/7 samples. Everytime, independent from any buffer settings.
best regards
Knut
Whoa - How did I miss this :-)
best regards
Knut
Hi Knut !
Thats AWESOME - that means if I am right that overall - input and output - the overall AD/DA Latency is ~50 Samples less than my UC ...... and ~50 Samples is approx. just on 1.0ms ........ so, whereas my UC gives me a real-world [ CEntrance measured ] RTL of 3.95ms @ 88.2k / 24 Bit ........ the UCX at 88.2k / 24 Bit will deliver a real-world RTL of ~2.95ms ......... please tell me my maths and latency analysis is correct ?
If so, that is simply ASTOUNDING !!!!!!!
Ben
I think the advantage of 50 samples less is not a full ms at 88.2, but around a half and 1.1 ms at 44.1 kHz.
best regards
Knut
HEHE...no wonder.
Nowhere written AFAIK....
Zapp
It's written in the product text, in the converter section.
best regards
Knut
Are the converters the same as the ones used in the UFX? I don't need a name just wondering if they are different in any way.
You will be able to answer that question with a look at the tech specs.
