1 (edited by patrickw 2012-02-18 16:26:23)
Topic: Fireface 800 with adi-8qs
I have the opportunity to buy a used adi-8qs . Will it work well together with the fireface 800 via adat ? I know adi-8qs has top converters thats why i want to buy it . I could also think about a adi-8ds . Are the converters the qs and the ds the same ?
Must i use firewire 800 to make it work together with fireface 800 ? Or should i connect the other way ( fireface800->adi8"x"->pc? )
Or would you suggest an other connection ?
Re: Fireface 800 with adi-8qs
No FW800 needed, that is needed with 2 firefaces.
Connect to fireface through adat, use dual adat cables for higher sample rates (smux).
For best quality use ADI8 as master clock (sync through adat)
thanks .
Are the converters in adi-8ds and adi-8qs the same ?
No. The QS has better specs and more features.
best regards
Knut
