Topic: HDSPe Card, Multiface and Cubase 5 Compatibility
First post - long time Multiface user.
Previously I was running a Multiface I on a PC with XP using a PCI card and Cubase 5 with no problems. I upgraded to a Windows 7 PC which required a HDSPe PCI Card to use the Multiface. At first install of Cubase everything opens up fine, but after installing the PCIe Card and latest WMD Driver Cubase gets hung up on "Initializing: All MIDI Inputs" and will not open. If I un-install the WMD driver, Cubase opens right up, but the RME interface is not available as a VST Connection.
I have uninstalled and re-installed Cubase and the RME drivers and nothing works. Is there a known compatibility issue with the latest WMD drivers and Cubase 5? I have read posts from other users on forums regarding the same message with other devices and Cubase which suggests it may be on Steinberg's end. I have sent the same inquiry to Steinberg support as well.
The RME interface is installed correctly and all drivers are up to date. Please offer any suggestions you may have to resolve this issue.
HDSPe PCI Card
Multiface I
Gateway PC DX- 4860
Intel Core i5-2320 3.0GHz
Windows 7
64-bit Operating System
8GB Ram
Cubase 5 64-bit ver. 5.5.3
Thank you very much in advance for your help.
