RME Support wrote:Es kann immer nur ein MADI-Eingang aktiv sein. Ausgänge laufen parallel.
Remote ist von der Eingangswahl prinzipiell unabhängig. Wenn der Kartenausgang auch opt. mit dem 648 verbunden ist, sollte das auch gehen...
mfg
D. Fuchs
For the English folk - Here's the Google Translated version:
RME Support via Google Translate wrote:There can be only one MADI inputs to be active. Outputs in parallel.
Remote is in principle independent of the input selector. If the card's output also opt. connected to the 648 is, it should go ...
So, you are basically saying the MIDI Remote prunes the MIDI signal pre MADI Input Selector? What does it do if it were to receive 2 conflicting MIDI notes on BNC and Optical MADI at the same time?
It would seem that the MIDI Remote is actually looking at the MADI Input Selector's output opposed to the physical MADI Inputs themselves.
Revision - Yep - The ADI648 manual clearly shows the MIDI Remote "Decoder" taking its MADI MIDI feed "Post MADI Input Selector" (pg 18 of the manual). Now, if you use "Redundant/Auto-Failover" mode with a common MADI card, this would still work in tandem with the failover. But since HMC is not actively "selecting" the Optical MADI Input, the HDSP MADI card isn't able to make a full MIDI I/O "loop" with the Optical MADI input selected on the ADI648.
I believe the other functionality you are trying to achieve should work (basically taking a BNC MADI Input plus some ADAT Inputs, and trying to combine them and send them out via Optical MADI to your RME MADI card). Of course, you will need to select the "BNC" MADI Input on the 648 for this to work - and both of the ADI-648's outputs will transmit an identical MADI signal based off your Matrix routing scheme (can theoretically feed Coax or Optical to your RME MADI Card).
Also - You can certainly use the 648 in 54-Channel Input Mode and 64-Channel Output Mode at the same time. This will net you an extra 8 Channels of MADI or ADAT to feed MADI Output channels 57-64 to the RME MADI Card (which handles 64-Channel mode as standard).
Also, I just got an ADI-648 MKII myself. I quickly tested the MIDI Remote (over MADI BNC Coax on a spare HDSP MADI card for now) and it seemed I had to set the MIDI Remote application to "MADI MIDI 3" to get it to "connect" and work? Is there any reason I could not get it to work with MADI MIDI 1 or MADI MIDI 2? Might have been user error as I only fiddled with it for a hot minute...
Enjoy!
2x SSL Alphalink MADI AX
