Topic: Fireface random crashes: Howto reset or switch on/off while operating?
Hey there,
I got a Fireface 400 running under Windows 7 64bit. I've installed driver version 3.062 and the latest firmware, but the Fireface crashes from time to time. The error occurs randomly after closing a program (last time on Firefox, before it was NI Kontakt...) After that I don't get any sound and the drivers can't be loaded anymore. Checking the Fireface Settings showed that the Clock Mode's Sample Rate was set to 1371828 Hz (pitch at 3010.721%)! I can't change these parameters and only shutting down my PC helps to make the Fireface reset and work again. Is there anybody who's experienced similar problems or maybe got a hint what this error could be caused by? I'd be happy already if there was a way to reset the Fireface without shutting down my PC or Hot-Plugging! THX for Help
