Topic: blinking lights/clicking sound/driver not recognized/can't open soft
I've been using the Fireface 800 for many years without problems. Today I went into the studio and all the lights on the unit are flashing and it is making a clicking sound through the monitors. I tried to open up the Fireface Settings and the Firerace Mixer, both of these icons/applications will not open. I tried using the Fireflash flash, but it says it doesn't recognize a driver....
I've tried the following:
* Reset PRAM/NVRAM
* Repaired disc permissions
* Left unit on, and unplugged the power cable--waited 10 seconds and plugged it back in.
* I've tried to delete the files and re-install the software to no avail.
Help--I don't know what to do or why this is happening.
Additionally, can someone also recommend how to do a full clean uninstall. Not sure I'm doing it correctly, but I trashed the mixer/settings icon and additionally went into the library/extensions folder and deleted the 1 fire face item (FirefaceAudioDriver.kext)...Are there more items to delete? Is there a FireFace Uninstall application or by simply deleting the 2 Fireface icon/applications this will take care of?
So-ANY help would be appreciated. I'm running a iMac 10.7.3, 2.4 GHZ, 4 GB 800-MHz DDR2 SDRAMM - use logic (however this is not the issue as it is happening before running Logic/Ableton/itunes or any programs). Furthermore in the system preferences it doesn't recognize the FireFace RME
Very frustrating---
Thanks in advance,
Joseph
