Topic: ADI-2 Connection to Laptop USB or PCMCIA
Greetings to All,
I have a large vinyl collection that would like to copy to digital format.  There are some low and high cost USB hardware options, but the ADI-2 seems to have a number of advantages.
I'm not crazy about going with anything that will take a turntable phono input directly, I don't see how it could have a better phono stage than my Audio Research SP-16.  From my preamp I can go with an unbalanced line output from a tape out jack.  If I need to convert from unbalanced to balanced, I'm OK with that.
The issue seems to be with connection to a laptop.  Connection can be with a PCMCIA card or to a USB port.
If I want to use the ADI-2, it doesn't seem to have the Cardbus connector for the RME ExpressCard, that seems to connect only to other multi-channel digital interfaces, and I only need two channels.
The other option seems to be using the SPDIF or ADAT digital outputs from the ADI-2 to the laptop, but I have not found any type of interface card that will do that, at least not with a PCMCIA format.
It does seem odd that the ADI-2 does not have the RME bus protocol connection so that the ExpressCard can be used, or am I missing something?
I can't be the first person who wants to do this, can I?
Any help would be greatly appreciated.  I am aware of standalone 2 channel ADC's made by others that will connect directly to a USB 2.0 port, but I do like the specification and clean design of the ADI-2.
Thank You,
Stephen
North Bay, Ontario
Re: ADI-2 Connection to Laptop USB or PCMCIA
The ADI-2 is a standalone converter - no USB, no Cardbus. You can essentially connect it to a laptop with any USB based audio device that has got an SPDIF I/O.
You could also use the RME Babyface as an alternative, which connects to USB.
Daniel,
Thanks for the quick response, much appreciated.  That was my thought as well, I can go with the Babyface to USB and simply use the channels that I need.  Now, all I need to do is figure out which software program will be the least painful for ripping vinyl.
Stephen
North Bay, Ontario
Interesting ....
My contribution did vanish since yesterday in the evening.
Probably because it offered a cheap "non RME" solution?
Cheers!
Mathias
ed:
You are looking for it in the wrong thread... Nothing was removed...
fryingpan
Believe it or not.
I just checked my Browser history.
Mathias
http://www.rme-audio.de/forum/viewtopic.php?id=1695
Uups ....
Full and frank apologies !!!
I'm truly sorry.
Mathias
:-P :-)
All is well....
