Topic: very high latency with FF800 in ableton after upgrading from ff400
ok, i have been silly enough to change my lovely ff400 for a ff800 because i needed more ins... now i find even on a small project of about 10 tracks of 96k audio even though just monitoring, i cannot go below 1024 samples and have a latency of around 24.1ms. with the 400 this did not happen. even when i am going to 48khz i still and at 256 samples i still have clicks and cracks even though i only move the loop marker tool around... and about 14ms of latency time...
I just find this not acceptable from an interface that retails at 1200€. I just had a presonus 8pre for a week, which i had directly comparing to the ff400. it had slightly higher latency than the ff400, but nothing compared to the ff800 - and most importantly, cost me 349€!!! but i gave it back because it would not record at 192khz.
now the tech stuff
ableton suite8
macpro 4 core 2.8 8gb dual channel memory from 2011
OSZ 10.6.8
macbook pro
intel dual core 2 2.55 4gb ram from 2010
osx 10.6.8
the ff400 run perfectly on both machines. no changes to hardware or software have been done and i tested the ff800 on both machines with the same problem as the result.
changed fw cables, no change
used fw800 and fw400 connection, no change
cleaned hhd and repared permissions on both machines, no change.
installed the latest drivers, latest version of daw, latest verion of waves gold, repared permissions again.. no change
reinstalled EVERYTHING new on the mac pro, no change.
now, Daniel Fuchs told me to install reaper and create a project in there to see if the problem persists.. i find this rather sad for a company that sells top of the shelf sound cards to refer to a program that hardly anybody uses - at least I know nobody who does commercial stuff with that - on top of that i dont know the ins and outs of that program..
I am starting to regret two things:
- having sold my fantastic ff400
- having spend double that money to get something thats not working and until now, has only caused me loss of time, and no joy.
its been about 3 or 4 weeks now... and all i get is excuses. i am not very happy.
any help is very very welcome.
Thank you all
