Topic: delay when using live recording
Hi all,
I am new to using the Babyface along with Sony Acid Pro7. When I want to record acoustic guitar and connect a microphone to the line input on the breakout cable I get a delay when monitoring (there is a slight disconnect between my fingers plucking the string and hearing it through the headphones) when I listen to the acoustic guitar through the headphones. If I connect the microphone into the instrument input on the side of the Babyface this does not occur. Can anyone suggest a solution to my problem.
regards
Roy
